Need help on how to get log files out of CM 5.x
shzhang
Anybody knows. Thanks!
Steve
Rob Huffman
Hi Steve,
This was nicely supplied recently by Java from Cisco. ;
Via RTMT (Trace Files)
Trace tab -> Trace & log central -> Collect files -> xxxx
Hope this helps!
Rob
you can also refer to this doc
Set Up Cisco CallManager Traces for Cisco Technical Support
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Note: i gotta say today it wasn't a bad friday shift Rob =). Have a nice weekend.
java
if this helps, please rate
java
