need help on uccx script
I just started working on a script on UCCX, and the office I'm writing the script for has the hours of 7:00am to 4:30pm M-F. However, on the first Wednesday of every month, their hours are 7:00am to 12:00pm. Is there any way I can write an *if, then* script to show this?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Eileen.
You can calculate it direct through a boolean variable in the script, or you can call an external XML.
I found esier to calculate it as follows
Define a bolean variable eg. called FirstWednesday
Than add a "SET" step in your script
Set FirstWednesday = {
        java.util.Calendar calendar = new java.util.GregorianCalendar();
        calendar.setTime(new java.util.Date());
        if (calendar.get(java.util.Calendar.DAY_OF_WEEK)  == java.util.Calendar.WEDNESDAY && (
                calendar.get(java.util.Calendar.DAY_OF_WEEK_IN_MONTH) == 1
            return true;
        } else {
               return false;
The value FirstWednesday will return true or false and , with this value, you can apply an if step setting the right time
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Eileen.
            return true;
        } else {
               return false;
Carlo
Carlo,
Thank you so much! I think it actually worked; it wasn't accepting anything else I was trying. It doesn't go into effect for a few weeks, but I'm crossing my fingers!
282
