Need help on Unity call flow.
Dear Friends. I want to know the call flow in the unity server. I want to know call flow for direct call and forwarded call.
Esa
Re: Need help on Unity call flow.
direct is when you call the pilot, FW when following a call forward option.
not sure if that's what you're looking for, if not, please elaborate
you can use the call viewer to see this
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi. Thank u for ur reply. I want to what happening when direct or forwarded call comes to unity.
thanks
esa
ok, the use the port status monitor if you want to see what happens to a call
java
java
I believe Unity use Direct Call Routing Rule when you push the message button on your phone (when checking voicemails) and if Voicemail account exist in Unity, it iwll take u to ur mailbox, prompt for a password.
In Forwarding rule, you get the greeting of that particular user. Used when someone try to leave u a voice message.....
155
