Need HELP. Phones dont ring sometimes
Hello, I am having a problem that i can not figure out. We have several users who complain that they get a voicemail and there phone didn't even ring and they were not on the phone. The phone simply does not ring. This happens on both external and internal calls. This will only happen sometimes and not all the time and to many different users. There line settings are set correctly. I did talk to one of the users that called the person and I asked if the phone rang like normal or if it went straight to voicemail. They said they dialed there extension and that it rang on there end like a normal call then went to voicemail. But the other phone did not ring and the only way they were notified of a call was the voicemail they left.
We are running CCM 5.1. Any help would be great!
Thanks!!
Re: Need HELP. Phones dont ring sometimes
The issue was related to high CPU utilization. Try antivirus on the call manager.
I have experienced a similar issue that I believe is the result of this bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsl22198
The only way I've found to resolve this issue is do a CFwdAll (Call forward all) to voicemail and then remove it. This should get the phone forward status synced back up with the call manager and the phone will ring again.
I just had this issue with a phone. Your solution worked perfectly.
96
