Need help to identify unused voicemail number in CUC
Some one help to identify logtime unused voicemail numbers in CUC.
Everyone's tags (2)
Please refer to this thread might help you.
https://supportforums.cisco.com/docs/DOC-13233
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hall of Fame Super Red
Re: Need help to identify unused voicemail number in CUC
Hi Sreenivasulu,
For Unity Connection
There is a perfect tool for this type of report. We have used this to search for the same "setup" info
Check the  "Set for First Time Enrollment" and "Voice name Recorded";
Connection  User Data Dump (CUDD) Tool
The  Connection User Data Dump (CUDD) is a  Windows-based remote database  administration tool available on the Cisco  Unity Tools website. CUDD  allows you to export specific information  about users to a file that  can be viewed or imported into another  application, such as a database  utility or Microsoft Excel. When the  data is exported, the tool  automatically creates a header row that lists  the data type found in  each column of the output, for ease of import  into other programs.
Here is a sample (where the 0 under first Time Enrollment means the user has
completed the setup and 1 means they have not gone through the Enrollment steps)
DISPLAY_NAMEPRIMARY_EXTENSIONSET_FOR_FIRST_TIME_ENROLLMENT
Rob Huffman70010
Ben Nutball68131
Or maybe you would want to check; from CUDD;
Time of Last Call. Indicates the date and time the user called in to check messages last.  This can be handy for finding out which boxes have not been accessed at all or which ones have not been accessed in a long time. This value is in GMT and not your local time, keep that in mind.
The tool is available from the "Superb" Unity  Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
And for unused mailboxes;
Tools > Reports > Unused Voice Mail Accounts Report .
Cheers!
Rob
***EDIT - +5 to my friend Nadeem for his good info
"Seek it out and ye shall find  "
- OneRepublic
212
