Need help to register cisco CP-6941 / CP-8941 with Asterisk server
2 Accepted Solutions
52 Replies 52
Leo Laohoo
Go HERE.
Thanks for the reply.
After following the steps, the SIP firmware and SEP[MAC_ADDRESS].cnf.xml uploaded on cisco 8941, but the phone is still not registered with Asterisk.
attached SEP[MAC_ADDRESS].cnf.xml
Try and use SIP version 9.0(4) for the phones.
Ok, will try this and update how it goes.
Thanks.
Hello ,
Please I have two Cisco IP phone 8941 that I need to use on a Asterisk server. I read all the posts and I still can not get it register please can anyone helps  me or the share the technical issues with these model.
I would appreciate any help / comments or suggestion.
Scroll up, I've posted TWO files (one for 9971 & the other for 8961) and use either one as your config.  Your current configuration is NOT using "USECALLMANAGER" so this alone will not work.
I thank you for your prompt answer I inform you that's OK now .
I appreciate your help. Good Job /Work
Merci
What have you done to get your phone to work?
Hello Leo Laohoo, i use yours configuration(cisco 8961) for my CISCO 8941, but remain in "phone not registered"
IP (tos 0xc0, ttl 64, id 51172, offset 0, flags [none], proto ICMP (1), length 576)
    192.168.199.207 > [PBX IP]: ICMP 192.168.199.207 udp port 54714 unreachable, length 556
    IP (tos 0x60, ttl 64, id 25153, offset 0, flags [none], proto UDP (17), length 596)
    [PBX IP].sip > 192.168.199.207.54714: SIP, length: 568
    SIP/2.0 401 Unauthorized
    Via: SIP/2.0/UDP 192.168.199.207:5060;branch=z9hG4bK4bc9ad6b;received=192.168.199.207;rport=54714
    From: <sip:645@ [PBX IP]>;tag=8478acedd9e900083f65c792-218060a6
    To: <sip:645@ [PBX IP]>;tag=as669ee78c
    Call-ID: 8478aced-d9e90006-134a4358-686985eb@192.168.199.207
    CSeq: 106 REGISTER
    Server: FPBX-12.0.76.4(11.25.1)
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
    Supported: replaces, timer
    WWW-Authenticate: Digest algorithm=MD5, realm="a[|sip]
Why?
Phone information:
MAC Address 8478ACEDD9E9
Host Name SEP8478acedd9e9
App Load ID SIP 9-2-1-00
Boot Load ID 0.0.0.9
Hardware Revision 3
Version V02
Serial Number PUC170200K7
Model Number CP-8941
I had all in place and take file the forum leave usecallmanager only a few change is needed. But tthe big problem is than the video call does not work.
I made the change in the sip.conf
[general]
videosupport=yes
and allow the h263 & h264 for the 2 devices.
Still does not work but the basically is OK
are you able to register 8941 to asterisk if yes! please let me know which firmware you user and please share sample. mac.cnf.xml file
9.0(4) release is not available on cisco download site. The oldest available release is 9.2(1)
Following are the available releases, please suggest which one to try.
9.4(1)SR1, 9.4(1), 9.3(4), 9.3(2)SR1, 9.3(2), 9.3(1), 9.2(3), 9.2(2), 9.2(1)
I am able to register the phone to Asterisk server.
Many thanks for providing information.
Regards, Sandeep
What have you done to do this?
