Highlighted
Community Member
Need help to register Cisco IP Phone 7975 with Asterisk server
It does'nt register.
It just keeps saying "Registering" but it does'nt register...
Please? Someone?
Ps: My XML is attached. ( Of course i changed the IP and the file name - Since its my IP and my MAC in there. )
What am i doing wrong?
1 REPLY
Hall of Fame Super Blue
Re: Need help to register Cisco IP Phone 7975 with Asterisk server
Where did you get this config from?
The phone is loaded with 9.X firmware, therefore the proxy settings should be using "USECALLMAMANGER".
Where is the config for the NAT (or not)?
When the phone is registering, look at the status messages. I bet the phone is complaining that the SEPmacaddress.cnf.xml file has invalid lines.
Search this forum, I've posted working configuration for the 9951/9971 and with little modification the same configuration can be used by the 7975.
84
