Need help with removing CME configuration for CM install
Hi Everyone,
I'm planning to test my CallManager install. But first, I plan to backup the IOS configuration on the our production router. Then do a no telephony-service command to remove CME from the router. Input the MGCP commands and test away. My question is, will I be able to restore my saved IOS configuration so that CME is back to original state after testing? Also, is this the best way to remove CME for CM implimentation without messing everything up. Thank you for all your help.
1 REPLY
Gold
Re: Need help with removing CME configuration for CM install
I've not really tested this, but AFAIK, there is no CME configuration stored in the RAM. So if you copy the previous configuration to the start up config and reload the router after you are done with the testing, CME should be back online without any issue.
93
