Need help with translation rules and CME
Hey guys I have a CME system at my small business and I am now in need of translation rules because my internal 3 digit numbering plan conflicts with some area codes in the US.
I want users to have a dial a 9 then the 10 digit phone number for local calls.
I also want users to have dial a 9 then 1 then the 10 digit number for long distance.
However my provider will only accept the 10 digit phone number for both local and long distance calls.
Any help is appreiciated.
Hall of Fame Super Gold
Re: Need help with translation rules and CME
No need for translation rules in this case:
dial-peer voice 9 pots
description local calls
destination-pattern 9[2-9]......
prefix 408 <- your area code here
port x/y
dial-peer voice 91 pots
description long distance
destination-pattern 91[2-9][0-8].[2-9]......
forward-digits 10
port x/y
Hi I am using VOIP dial-peers. I cannot use the prefix command and it does not strip off the first number in the destination-pattern command. Already tried that. I need translation rules.
You should have mentioned the SIP trunk :)
voice translation-profile 9-to-area
translate called 100
voice translation-profile strip-9
translate called 101
voice translation-rule 100
rule 1 /^9/ /408/
voice translation-rule 101
rule 1 /^91/ //
dial-peer voice 9 voip
translation-profile outgoing 9-to-area
dial-peer voice 91 voip
translation-profile outgoing strip-91
We have to dial 10 digits here in Houston.
I think translation rule 100 needs to look like this:
rule 1 /^9/ //
Correct?
What should the destination pattern read? I tried this config real quick and it didnt work so i had to revert back.
I used 9[2-9]......... for the destination-pattern on the dial peer.
What did I miss? Any way to test the translation rules before applying them?
Hi, seems to me the rules are right, of course replace my example 408 with your area code.
You can "test voice translation-rule XXX YYY".
Thanks for the appreciation and good luck!
I did my rule like this
rule 1 /^9/ //
Remember I need to dial a 10 digit number.
NANP:
Area code (3), exchange code (3), number (4) = 10
BUT, you also need to remove the 1 used for long distance in the US.
So the rule should be really
rule 1 /^91/ //
That removes the leading 91. If you are supposed to leave 1 in place, you'll be calling 11 digits, not 10.
For local and long distance numbers I DO NOT have to dial a 1. I need to give my phone company 10 digits period. I want my internal users to dial a 9 then the 10 digit number for local calls. For long distance I want my internal users to dial a 91 then the 10 digit number.
Remember my phone company will only accept a 10 digit number no matter if it is long distance or local. They dont care one way or the other.
Well, that is exactly what the rules I suggested above do.
For local calls, leading 9 is replaced with you area code. For long distance, leading 91 is removed. In both cases, 10 digits are sent.
I suppose that for international, 011 has to be prepended and destination-pattern would look like: 011[1-9].....T
Another translation-profile and rule would ensure that 9 is prefixed to calling number for incoming calls, this to facilitate callback.
You can check which number is ultimately sent to ITSP with "debug ccsip message" and "term mon".
OH I think where I was getting confused was Houston has 3 area codes, 281, 713, and 832.
I will make a rule 1 /^9/ // with a destination-pattern of 9[2-9].........
But that will make users dial 9 followed by 10 digits, that I think is not customary in the U.S.
I guess you've to decide which one of the three area codes is your "local" one.
YES, that is exactly what I want. I need my users to dial 9 then the 10 digits. In major US cities this is normal.
OK here is another question for you. My home CME system I want the users to dial 9 then the 10 digit number however my SIP provider wants a 1 in front of the 10 digit number. What does the rule need to look like to accomplish this?
Have to admit I misunderstood the 9 + 10 digits thing since the very beginning.
I also do not understand what is the point to have to remember that for three area codes only, no 1 needs to be dialed. In my way of thinking, either 1 or no 1, all calls should go through.
Anyway, what do you want is done with:
voice translation-profile strip-91
rule 1 /^91/ //
rule 1 /^9/ //
dial-peer voice 9281 voip
destination-pattern 9281[2-9]......
translation-profile outgoing strip9
dial-peer voice 9713 voip
destination-pattern 9713[2-9]......
dial-peer voice 9932 voip
destination-pattern 9832[2-9]......
I agree this is the way the customer wants it though and it was the way the old phone system was setup. It is easier to reconfigure the phone system than to reconfigure 75 users.
how about predot trailing # discard? i've just decided to move from MGCP to h323 and am having a hard time figuring that one out..
HI, discussion was about a CME where SIP is used to ITSP. H.323 and MGCP do not apply in this case.
482
