Need helpt to change extensions
We need to change around 1000 extensions and also change from 4 digits to 5 digits on an existing call manager.
Is there a way we can do with some tools or XML applications? I really don't want to change those manually.
CM is 4.1.3 sr3
Thanks for your help.
Bala
Re: Need helpt to change extensions
Brandon,
I knew about the BAT tool.It pulls lot of information when you try to query about the phones.I'll try that again.
Thanks for your help though.
Bala
Bala,
Yes, you can use the BAT tool to accomplish this. You could export the existing phones to a .csv file, fix up the file and use the .csv to update the phones. Take a look at the BAT User Guide below.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00807184bb.html
Hope this helps. If so, please rate the post.
Brandon
105
