Community Member
Need info regarding 72-GB USB external Digital Audio Tape (DAT) drive
Hello All!
I am trying to get some information about part no :DAT-USB-EXT-72
I know that it is a 72-GB USB external Digital Audio Tape (DAT) drive and it is used with CUCMs and is connected to the USB Port on the MCS Server.
I tried to get some documents/brochures about this product, but couldn't find any. Can anyone help please? Any documents / links related to the product or (and) its configuration - would help.
Thank you all...
Kalesh Kumar S G
1 REPLY
Silver
Re: Need info regarding 72-GB USB external Digital Audio Tape (D
You can have a DAT-USB-RM-72 on your server depending on the model. You can do system backups on DAT-USB-RM-72 as long as you use DIRT as it's the supported Cisco software for doing unity backups.
http://www.cisco.com/en/US/ts/fn/620/fn62476.html
107
