Need quick help to forward all calls
         Hi ,
I need quick help to forward all calls to respctive number.
requirement:I want forward all calls when user pickup receiver
we are connected phone to FXS port in router and router configured as aMGCP gateway.
I given command connection plar under FXS port,and router successfully registed with CUCM,but when user pickup receiver geting fast busy tone.
Is ther any way to configure like connection plar in CUCM.
voice-port 0/2/0
connection plar 92143319630
voice-port 0/2/1
rtr189#show ccm-manager
MGCP Domain Name: rtr189
Priority        Status                   Host
Primary         Registering with CM      X.X.X.X
First Backup    Backup Ready             X.X.X.X
Second Backup   None
Everyone's tags (3)
Green
As you are using MGCP the IOS config line is ignored.
Take it back out of the config
voice-port 0/2/0
no connection plar 92143319630
voice-port 0/2/1
On cucm admin
Device----> Gateway
Find your gateway
Select the end point for 0/2/0
Look down the setting to Porrt Information (Loop or Ground Start)
Type the number you want to call in the Attendant DN box
save
Test and let us know how it goes
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Alex,
Kindly let me now whether i have to mention port direction inbound r outbound.
Green
Direction both ways
Alex.
WE are geting dial tone but not dailing number
Green
Sorry my mistake.
The Attendant DN fild is for incoming calls.
Please delete the number from the field.
Can you please try this instead:-
(Names are only suggestions)
1) Create a new Partion
PT-FXS-HOTLINE
2) Create a new CSS
CSS-FXS-HOTLINE
Assign only the Partition
PT-FXS-HOTLINE
3) Create a new Tranlation Pattern
Just put a "." as the actual Translation Pattern
Assign to Partition PT-FXS-HOTLINE
Description FXS-HOTLINE
Calling Search Space - Select a CSS that has access
to the partition that your target dialled number resides
Called Party Transform Mask - YOUR TARGET DN
4) Go to the gateway endpoint
Remove the Attendant DN
Change the CSS to CSS-FXS-HOTLINE
Test again
Alex.
329
