10-11-2013 08:57 PM - edited 03-16-2019 07:51 PM
Hi ,
We are implementing sip in our business and we tested the dummy numbers on sip it is working fine.
When we test our main numbers it is not working for incoming or outgoing calls. it is giving sip error error 404.
I am using CUCM 8.6.2
Any ideas.
Oct 12 03:52:23.198: //418747/863B1AC6BE1B/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2BCB7F60
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 0861036261
Called Number : 0893640881
Source IP Address (Sig ): 123.102.100.34
Destn SIP Req Addr:Port : 123.102.30.131:5060
Destn SIP Resp Addr:Port : 123.102.30.131:5060
Destination Name : 123.102.30.131
Oct 12 03:52:23.198: //418747/863B1AC6BE1B/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 123.102.100.34
Source IP Port (Media): 26776
Destn IP Address (Media): 58.105.248.129
Destn IP Port (Media): 55094
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 1
Disconnect Cause (SIP) : 404
Oct 12 03:52:27.038: //418717/84AF9822BDCD/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BC63A50
Calling Number : 0478403561
Oct 12 03:52:27.038: //418717/84AF9822BDCD/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 18150
Destn IP Port (Media): 44382
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 487
Oct 12 03:52:27.042: //418721/84AF9822BDCD/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BCBD950
Oct 12 03:52:27.042: //418721/84AF9822BDCD/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Port (Media): 19128
Destn IP Address (Media): -
Destn IP Port (Media): 0
Oct 12 03:52:27.502: //418722/84F0E7CCBDDA/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x2BC8AFE0
10-11-2013 09:35 PM
HI Rohit,
Please share debug ccsip all for both incoming and outgoing call separately in notepad.
Also please give your call flow i.e from where to where you are calling or called etc..
Nishant Savalia
10-11-2013 09:45 PM
10-11-2013 10:00 PM
Hi Rohit,
Logs don't show any kind of messages exchanged. Can you please share "debug ccsip all" or "debug ccsip message".
Also please mention your call flow (e.g. pstn----sip---->gateway-------sip trunk----> cucm). Mention your call flow.
Nishant Savalia
10-11-2013 10:47 PM
10-11-2013 11:27 PM
Hi Rohit,
CUCM releasing the call because it's unable to find the called number received i.e. called number does not exist in dial-plan.
Check below points:-
1). Check the CSS on the SIP trunk in CUCM (may be called number is not accessible due to incorrect CSS).
2). Check the translation pattern and it's CSS.
3). If you are not using translation pattern then check for the translation profile in router config. In this case you can check and share your running-config and debug voice dial-peer or debug voice ccapi inout.
Nishant Savalia
