Need serious help. New 8831 phones having problems.
Thank you in advance for helping with this.
I recently rolled out new 8831 conference phones to replace my old 7937 spider phones, unfortunately the phones are experiencing terrible incoming audio. The phones are at a branch site, connected via MPLS and registered to CUCM 8.6 at HQ. We have a total of 900 7940 phones that have no issues at either location, and bandwidth/congestion is not a problem. The poor incoming audio is happening on every call. Outgoing audio is fine. 8831 phones are having the same issues at several branch sites, but seems more predominant in some. The issue has been described as "static, choppy, distorted audio, with some breakups".
I have tested with both G.729 and G.711 without any luck, after using the web interface to grab stats here's what they look like:
Remote Address
Local Address
Start Time  10:33:26a
Stream Status  Active
Host Name
Sender Packets  7180
Sender Octets  143600
Sender Codec  G.729
Sender Reports Sent  0
Sender Report Time Sent  00:00:00
Rcvr Lost Packets  2215
Avg Jitter  20
Rcvr Codec  G.729
Rcvr Reports Sent  0
Rcvr Report Time Sent  00:00:00
Rcvr Packets  7178
Rcvr Octets  143560
MOS LQK  2.8657
Avg MOS LQK  2.3054
Min MOS LQK  2.0000
Max MOS LQK  3.0295
MOS LQK Version  0.95
Cumulative Conceal Ratio  0.1356
Interval Conceal Ratio  0.0560
Max Conceal Ratio  0.2766
Conceal Secs  140
Severely Conceal Secs  120
Latency  40
Max Jitter  160
Sender Size  20 ms
Sender Reports Received  0
Sender Report Time Received  00:00:00
Rcvr Size  20 ms
Rcvr Discarded  1266
Rcvr Reports Received  0
Rcvr Report Time Received  00:00:00
As you can see the MOS is pretty bad, jitter and dropped packets seem bad too. Intra-site tests have resulted in better looking numbers. Initially I immediately thought "QoS" but all the other phones are fine and the issue is with INCOMING audio not outgoing.
Any comments on this are appreciated.
Thanks.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Bronze
Hi, As you can see receiver
As you can see receiver lost packet count is very high which will cause choppy audio. It looks like you are facing below defect
https://tools.cisco.com/bugsearch/bug/CSCuq03746
Also can you make sure codec used is g729r8 not g729br8. g729br8 has inbuilt VAD feature so it will drop some packets. Also disable VAD in any voip dial peer using "no vad" command.
Mohit Singh
1 REPLY
Bronze
Mohit Singh
1108
