Need some Help configuring sip
Hi all ! ,
Im kind off new to sip calling and cisco telephony , but here goes ,: i have a 2821 router with CME installed
IOS : C2800NM-IPVOICEK9-M
Sofware version : 15.1(4)M4 / CME 8.6
Attached to GE0/0 is a CISCO 3750 switch
GEO - consisfts of 3 VLANS  , the native
172.22.1.X
172.22.100.X VOICE
172.22.101.X DATA
my tftpserver = 172.22.1.150
i need some help configuring a sip trunk , i have 10 testing phonenumbers from vodafone , but i do not know where to start to get this working
i have tried
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
but im getting stuck with what to fill in where .. is there anyone form NL whom has the same setup ? or similar ? or can give me some guidance on how to make the test calls
Hi Vincent.
With conf you uploaded, your are at good point.
Now you should receive authetication credentials from you TSP for both receive and place calls.
Once you have your account, you have to add it undre sip-ua configuration section.
Eg.
sip-ua
authentication username "user" password "password" realm tspdomain.com (valid to authenticate for outgoing calls)
credentials username (or number) "username" password "password realm tspdomain.com (valid to receive calls)
registrar 1 dns:sipregistrar.com:5060 (you can add up to 6 registrar in case of different services)
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo ,
thanks for your quick reply :
is the user "phonenumber"  eg
0101234567@blah.com ?
Hi Vincent.
Yes sure could be the telephone number and, in this case, to authenticate for incoming calls, you should add.
credentials number password realm blah.com
Carlo
Hi Carlo ,
Ok . i have added the info which vodafone provided me , is there any way to trace this ? eg
picking up the horn ?
i have tried debug callmanager events .. which shows me picking up the horn but im unable to verify the connection to sip?
Try using the show commands in the document below:
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-vrfy_trouble.pdf
1. show sip service
2. show sip-ua register status
3. show sip-ua statistics
4. show sip-ua status
5. show sip-ua timers
aha !
thanks james for the command , however i think i have done something wrong :
Router#show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
0262610290                       -1         138          no
2626102901                       20002      138          no
901                              20001      138          no
Router#show sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): DISABLED
SIP User Agent bind status(media): DISABLED
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
Out-of-dialog Refer: DISABLED
Presence support is DISABLED
protocol mode is ipv4
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio video image
Network types supported: IN
Address types supported: IP4 IP6
Transport types supported: RTP/AVP udptl
Re: Need some Help configuring sip
Hi Vincent.
Please post relevant sip-ua configuration
thanks
Carlo
Hi Carlo ,
i dont quite understand what u mean by relevant , as u know im from the netherlands , and the CME config i spitted in there is from a USA config posted on the cisco site , i duplicated that and now trying to get sip to work
i have 10 testing phone numbers , eg 0262610290 through 9
i have connected 1 ephone with the explained 901 extention as shown in the example
if i dial the number from my phone , the call is received on the modem , but does not get to the 2821
i can ping the vodafone RTR from my 2821 console , apperently im missing something
i can use the number as sip user , but im uncertain how to go from there?
after enabling the debug ccsip messages the following log appears
Router#debug ccsip messages
SIP Call messages tracing is enabled
Router#
Jan  2 14:28:00.875: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:62.140.159.225:5060 SIP/2.0
Via: SIP/2.0/UDP 172.22.1.51:5060;branch=z9hG4bK5B1A
To: <2626102901>
Date: Thu, 02 Jan 2014 14:28:00 GMT
Call-ID: F7CC4D1-72F011E3-8003C222-F14BE05E
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1388672880
CSeq: 4 REGISTER
Contact: <2626102901>
Expires:  3600
Supported: path
Content-Length: 0
Jan  2 14:28:00.883: //50/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable - registrar unavail or not enabled
To: <2626102901>;tag=42F4ABC0-9E1
Date: Thu, 02 Jan 2014 13:51:55 GMT
Server: Cisco-SIPGateway/IOS-15.2.4.M3
CSeq: 4 REGISTER
Content-Length: 0
Jan  2 14:28:04.871: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.22.1.51:5060;branch=z9hG4bK62467
To: <901>
Date: Thu, 02 Jan 2014 14:28:04 GMT
Call-ID: F307A93-72F011E3-8002C222-F14BE05E
Max-Forwards: 70
Timestamp: 1388672884
CSeq: 4 REGISTER
Contact: <901>
Expires:  3600
Supported: path
Content-Length: 0
Jan  2 14:28:04.879: //51/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <901>;tag=42F4BB5C-D6C
Date: Thu, 02 Jan 2014 13:51:59 GMT
CSeq: 4 REGISTER
Content-Length: 0
Jan  2 14:28:08.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.22.1.51:5060 SIP/2.0
Via: SIP/2.0/UDP 62.140.159.226:5060;branch=z9hG4bK3F1B21AD1
To: <172.22.1.51>
Date: Thu, 02 Jan 2014 13:52:02 GMT
Call-ID: E4A0F55B-72EB11E3-B23DD474-C3882D2E@62.140.159.226
User-Agent: Vodafone-NL-SIP-Gateway-V1.0
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <62.140.159.226:5060>
Content-Length: 0
Jan  2 14:28:08.671: //52/EF79772E803E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.22.1.51>;tag=661B8-F5C
Date: Thu, 02 Jan 2014 14:28:08 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 101 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 166
v=0
o=CiscoSystemsSIP-GW-UserAgent 3073 3407 IN IP4 172.22.1.51
s=SIP Call
c=IN IP4 172.22.1.51
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
Jan  2 14:28:09.655: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 62.140.159.226:5060;branch=z9hG4bK3F1B38C9
To: <172.22.1.51>
Date: Thu, 02 Jan 2014 13:52:03 GMT
Call-ID: E537B92C-72EB11E3-B23ED474-C3882D2E@62.140.159.226
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
Jan  2 14:28:09.659: //53/F010389D803F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.22.1.51>;tag=66594-16BD
Date: Thu, 02 Jan 2014 14:28:09 GMT
CSeq: 101 OPTIONS
Y, INFO, REGISTER
Content-Length: 166
v=0
o=CiscoSystemsSIP-GW-UserAgent 2096 2958 IN IP4 172.22.1.51
s=SIP Call
t=0 0
Jan  2 14:28:09.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 62.140.159.225:5060;branch=z9hG4bK3F1B4CEB
To: <172.22.1.51>
Call-ID: E5398E3D-72EB11E3-B23FD474-C3882D2E@62.140.159.225
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <62.140.159.225:5060>
Content-Length: 0
Jan  2 14:28:09.671: //54/F0120DAE8040/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.22.1.51>;tag=665A0-11
CSeq: 101 OPTIONS
Y, INFO, REGISTER
Content-Length: 165
v=0
o=CiscoSystemsSIP-GW-UserAgent 7454 235 IN IP4 172.22.1.51
s=SIP Call
t=0 0
Jan  2 14:28:10.755: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 62.140.159.225:5060;branch=z9hG4bK3F1B5214B
To: <172.22.1.51>
Date: Thu, 02 Jan 2014 13:52:05 GMT
Call-ID: E5DF95C5-72EB11E3-B240D474-C3882D2E@62.140.159.225
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
Jan  2 14:28:10.759: //55/F0B811668041/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.22.1.51>;tag=669E4-32E
Date: Thu, 02 Jan 2014 14:28:10 GMT
CSeq: 101 OPTIONS
Y, INFO, REGISTER
Content-Length: 166
v=0
o=CiscoSystemsSIP-GW-UserAgent 7723 2893 IN IP4 172.22.1.51
s=SIP Call
t=0 0
can anyone shed some light on this ?
ok .. i figured out the register ,
so i have configured 5 phones , which are reachable from the outside ,
trying to dial myself back is not working .. i think it has something to do with the dial rules
Hi Vincent.
My question was if you can upload here the router config after changes that I suggested.
Carlo
ok.. here goes
Building configuration...
Current configuration : 9721 bytes
! Last configuration change at 15:26:14 CET Thu Jan 2 2014
! NVRAM config last updated at 15:26:14 CET Thu Jan 2 2014
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CET 1 0
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
dot11 syslog
ip source-route
ip cef
ip dhcp pool VOICE
network 172.22.100.0 255.255.255.0
option 150 ip 172.22.1.150
default-router 172.22.100.1
ip dhcp pool DATA
network 172.22.101.0 255.255.255.0
default-router 172.22.101.1
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice service voip
ip address trusted list
  ipv4 172.22.1.50
  ipv4 172.22.1.51
  ipv4 172.22.100.1
  ipv4 172.22.101.1
  ipv4 62.140.159.225
callmonitor
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice register global
voice translation-rule 1
rule 1 /5123781291/ /601/
rule 2 /5123781290/ /600/
voice translation-rule 2
rule 1 /^112$/ /112/
voice translation-rule 3
rule 1 /^.*/ /0262610290/
voice translation-rule 4
rule 2 /600/ /5123788000/
rule 3 /601/ /5123788001/
rule 4 /^2(..)$/ /51237812\1/
voice translation-profile CUE_Voicemail/AutoAttendant
translate called 1
voice translation-profile PSTN_CallForwarding
translate redirect-target 4
translate redirect-called 4
voice translation-profile PSTN_Outgoing
translate calling 3
translate called 2
voice-card 0
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
ip ftp username cisco
ip ftp password cisco123
ip tftp source-interface GigabitEthernet0/0.1
no ip address
duplex auto
speed auto
no keepalive
encapsulation dot1Q 1 native
ip address 172.22.1.51 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 172.22.101.1 255.255.255.0
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 172.22.100.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex full
speed 100
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
interface BRI0/1/1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http max-connections 16
ip http path flash:gui
ip route 0.0.0.0 0.0.0.0 172.22.1.50
tftp-server flash:7941/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:7941/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:7941/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:7941/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:7941/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:7941/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:7941/term41.default.loads alias term41.default.loads
tftp-server debug
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/0/1:15
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
voice-port 2/0/12
voice-port 2/0/13
voice-port 2/0/14
voice-port 2/0/15
voice-port 2/0/16
voice-port 2/0/17
voice-port 2/0/18
voice-port 2/0/19
voice-port 2/0/20
voice-port 2/0/21
voice-port 2/0/22
voice-port 2/0/23
mgcp profile default
dial-peer voice 1 voip
description **Incomming Call from SIP Trunk**
translation-profile incoming CUE_Voicemail/AutoAttendant
session protocol sipv2
session target ipv4:172.22.1.50
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description **Outgoing Call to SIP Trunk**
translation-profile outgoing PSTN_Outgoing
destination-pattern 9........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip
description **Outgoing Call to SIP Trunk **
destination-pattern 9[2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4 voip
destination-pattern 9[0-1][2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5 voip
description **911 Outgoing Call to SIP trunk**
destination-pattern 911
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 6 voip
description **Emergency Outgoing Call to SIP Trunk**
destination-pattern 9911
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 7 voip
description **911/411 Outgoing Call to SIP Trunk**
destination-pattern 9[2-9]11
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 8 voip
description **International Outgoing Call to SIP Trunk**
destination-pattern 9011T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 9 voip
description **Star Code to SIP Trunk**
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
description **CUE Voicemail**
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
b2bua
session target ipv4:172.22.1.155
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 11 voip
description **CUE Auto Attendant**
destination-pattern 601
b2bua
codec g711ulaw
no vad
sip-ua
authentication username 0262610290 password 7 15020A1F173D24362C realm 62.140.1
59.225
authentication username 0262610290 password 7 021605481811003348
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:62.140.159.225 expires 3600
sip-server ipv4:62.140.159.224
host-registrar
telephony-service
max-ephones 58
max-dn 192
ip source-address 172.22.100.1 port 2000
calling-number initiator
system message testing
cnf-file location TFTP tftp://172.22.1.150/
load 7960-7940 P00307020200.loads
load 7941 SCCP41.8-4-2S.loads
load 7941GE SCCP41.8-4-2S
time-format 24
dialplan-pattern 1 26261029.. extension-length 3 extension-pattern 9..
voicemail 600
max-conferences 12 gain -6
call-forward pattern 9.T
moh music-on-hold.au
web admin system name admin password password
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
directory entry 1 101 name 101
create cnf-files version-stamp 7960 Jan 02 2014 08:40:49
ephone-dn  1
number 290 secondary 0262610290
name Phone 1
hold-alert 30 originator
ephone-dn  2
number 291 secondary 0262610291
name phone 2
ephone-dn  3
number 292 secondary 0262610292
name Phone 3
ephone-dn  4
number 293 secondary 0262610293
name Phone 4
ephone-dn  5
number 294 secondary 0262610294
label Phone 5
ephone  1
mac-address 0019.E88F.3BDD
button  1:1
ephone  2
mac-address 001E.4A92.0A27
type 7961
button  1:2
ephone  3
mac-address 0012.43F5.03AF
button  1:3
ephone  4
mac-address 000F.F7AC.502A
button  1:4
ephone  5
mac-address 0019.E851.090A
button  1:5
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
ntp master
end
Hi Vincent
As I suggested, to receive calls, you should add this configuration line under sip-ua section.
sip-ua
credentials number 0262610290 username 0262610290 password 7 021605481811003348 realm 62.140.159.225
Than post again a show sip-ua register status
Carlo
i am able to receive calls , i am unable to call something
i have added additional ephones to my setup
0262610291
0262610292
0262610293
and they all can recieve calls , but i cannot place calls to an outside line ..
i will add the setup cfg u proposed
0262610290                       20009      170          no
0262610291                       20011      89           no
0262610292                       20013      140          no
0262610293                       20015      135          no
0262610294                       20017      139          no
290                              20008      21           no
291                              20010      89           no
292                              20012      139          no
293                              20014      135          no
294                              20016      139          no
Hi Vincent.
From the output it seems that you are still unable to receive calls on that numbers.
Can you please post a debug ccsip messages to see why?
Carlo
Hi carlo ,
i am ABLE to recieve calls on all the numbers , i am unable to make calls
Vincent, can you please post a debug ccsip during a failnig call?
Carlo
SIP Call statistics tracing is enabled
Router#
Jan  3 09:28:47.099: //8371/46C07F7392FC/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4A9C2800
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 0262610290
Called Number            : 0065152305
Source IP Address (Sig  ): 172.22.1.51
Destn SIP Req Addr:Port  : 172.22.1.50:5060
Destn SIP Resp Addr:Port : 172.22.1.50:5060
Destination Name         : 172.22.1.50
Jan  3 09:28:47.099: //8371/46C07F7392FC/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.22.1.51
Source IP Port    (Media): 17324
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 127
Disconnect Cause (SIP)   : 200
hmmz
Hi Vincent.
I need a complete trace during an outgoing call to verify the issue.
What you posted is not so complete.
Carlo
Hi carlo ,
since i am unable to make a call , what setting u want me use ? using debug ccsip all is alot to paste
Hi Vincent.
Because you have a problem dialing out, a complete trace would be usefull to investigate your issue.
You can log your session with debug activated, put the result in a file (you can also zip it) and upload here using "attach file" on bottom of post editor.
Thanks again
Carlo
after looking @ the debug log i noticed an configuration error
- my ipv4 was 172.22.1.51 and it should have pointed to the external ip
once i edited the dial-peer voice 3 and 4 i was able to make calls to the outside world
what still bothers me is that the
show sip-ua register status command
does not show ANY registered peers
Hi Vincent
Once again, without any output of a debug ccsip messages, we cannot investigate further on your issue.
If you can, please post the debug output as suggested.
Carlo
Morning
this morning i placed a call from my Cisco Ephone to a cellphone , with "debug ccsip messages"
so maybe u can have a clue why my sip works , but my peers do not register
743
