Need some help with a config
I need some help with a config.  I can do a pri with my eyes closed, but this is older stuff, and not really used much any more.
I have a VWIC2-2MFT in a 2911 router.  In one port I have a PRI.  I have another T1 I want to plug in to the second port, but I know its not a PRI.  I think its an E&M 10 channel.  I'll attach the config from the voice card in the fax server its plugged in to.  We want to decommision that fax server, but I need to get the port on the router configured first so CallManager can accept the calls instead.  Does anyone know how to do this?  Attached below is the current config.
Bronze
It looks like T1 CAS with E&M signalling. Please go through below document which explains how to configure T1 CAS.
http://www.cisco.com/en/US/docs/ios/voice/isdn/configuration/guide/vi_imp_t1cas_voip_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Use the same framing and line code mentioned in snapshot.
Mohit Singh
I've tried this a couple times, but I'm not having much luck.  Here is the config in my router:
controller T1 0/0/1
cablelength long 0db
ds0-group 1 timeslots 1-24 type e&m-fgd
dial-peer voice 999101 pots
service mgcpapp
port 0/0/1:1
CallManager shows that registration is rejected.
Bronze
Instead of MGCP first try to use H323 and check using a dial peer whether you are able to send call to this port successfully.
Mohit SIngh
I dont know if thats an option, but correct me if Im wrong.  One of the ports is supporting a regular PRI that is bound to MGCP.
I'm being silly.  No reason I cant toss another router in just for this purpose.  I have a dozen 2800s in my server room.
Can anybody help me with the basic config to set this up as an H.323 router using the stuff I put above?
Bronze
controller T1 0/0/1
framing ESF
linecode B8ZS
Incoming voip dial peer for calls coming in from CUCM
dial-peer voice 20 voip
incoming called-number .
codec g711ulaw
Outgoing dial peer to T1 CAS port
dial-peer voice 30 pots
destination-pattern
port 0/0/1:1
forward digits < all or no. of digits you want to send to other end>
Also make sure under IP interface you configure "h323-gateway voip interface" and "h323-gateway voip bind srcaddr " for H323 to work. In CUCM create an H323 gateway.
If calls fail then collect below debugs for same call
debug vpm signal
debug voip ccapi inout
debug h225 asn1
Mohit Singh
Re: Need some help with a config
Thank you all for your help.  I called TAC last night, and we tinkered with it together and got it working.  I came to the realization that it was a delay start setup.  Here is the router config, and I'll attach a sreen shot of the CallManager config.  I ended up using MGCP.
controller T1 0/0/0
clock source internal
ds0-group 1 timeslots 1-24 type e&m-delay-dial
service mgcpapp
port 0/0/0:1
167
