need some urgent help vg224 cant fax outbound
drosenbaum
Inbound faxing works fine oddly enough, but cant figure out out why I cant do outbound.
16 Replies 16
kelvin.blair
Level 5
Level 5
Can you provide more information?
What version of Call Manager or CME? What is IOS version on VG224? How is the VG224 configured? SCCP or H323?
Can you provide us with a copy of your configuration?
FYI:
Here is the Configuration Guides for the Vg200 serious gateways.
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_installation_and_configuration_guides_list.html
ccm 6.0
sh ver
Cisco IOS Software, vg224 Software (vg224-I6S-M), Version 12.4(15)T3, RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Jan-08 11:40 by prod_rel_team
ROM: System Bootstrap, Version 12.3(7r)T2, RELEASE SOFTWARE (fc1)
una-usengu-vg1 uptime is 18 weeks, 5 days, 16 minutes
System returned to ROM by reload
System image file is "slot0:vg224-i6s-mz.124-15.T3.bin"
Cisco VG224 (R527x) processor (revision 4.1) with 119808K/11264K bytes of memory
Processor board ID FHK1151F048
R527x CPU at 225MHz, Implementation 40, Rev 3.1
1 On-Board Twenty-Four FXS Analog Voice Module V2.1
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
63K bytes of non-volatile configuration memory.
System fpga version is 250027
System readonly fpga version is 250025
Option for system fpga is 'system'.
62720K bytes of ATA Slot0 CompactFlash (Read/Write)
dial-peer voice 22 pots
service stcapp
port 2/2
dial-peer voice 23 pots
service stcapp
port 2/3
dial-peer voice 24 pots
service stcapp
port 2/4
dial-peer voice 25 pots
service stcapp
port 2/5
dial-peer voice 26 pots
service stcapp
port 2/6
dial-peer voice 27 pots
service stcapp
port 2/7
dial-peer voice 28 pots
service stcapp
port 2/8
dial-peer voice 29 pots
service stcapp
port 2/9
dial-peer voice 210 pots
service stcapp
port 2/10
dial-peer voice 211 pots
service stcapp
port 2/11
dial-peer voice 212 pots
service stcapp
port 2/12
dial-peer voice 213 pots
service stcapp
port 2/13
dial-peer voice 214 pots
service stcapp
port 2/14
dial-peer voice 215 pots
service stcapp
port 2/15
dial-peer voice 216 pots
service stcapp
port 2/16
dial-peer voice 217 pots
service stcapp
port 2/17
dial-peer voice 218 pots
service stcapp
port 2/18
dial-peer voice 219 pots
service stcapp
port 2/19
dial-peer voice 220 pots
service stcapp
port 2/20
dial-peer voice 221 pots
service stcapp
port 2/21
dial-peer voice 222 pots
service stcapp
port 2/22
dial-peer voice 223 pots
service stcapp
port 2/23
voice-port 2/0
timeouts ringing infinity
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
paolo bevilacqua
Which type of lines do you have on the POTS GW ?
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 5 priority 1
associate ccm 10 priority 2
connect inte
switchover method immediate
switchback method immediate
switchback interval 15
dial-peer voice 20 pots
service stcapp
port 2/0
dial-peer voice 21 pots
service stcapp
port 2/1
did my post answer your question?
Not really.
You should have another router that connects to PSTN, I'd like to see "show controllers T1" and "show network-clocks" from it.
ok coming right up
#sh controllers t3
T3 1/0 is up.
Applique type is Subrate T3
Description: verizon
No alarms detected.
MDL transmission is disabled
FEAC code received: No code is being received
Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Line
Data in current interval (860 seconds elapsed):
0 Line Code Violations, 0 P-bit Coding Violation
0 C-bit Coding Violation, 0 P-bit Err Secs
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
0 Unavailable Secs, 0 Line Errored Secs
0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 P-bit Coding Violation,
0 C-bit Coding Violation, 0 P-bit Err Secs,
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs,
0 Unavailable Secs, 0 Line Errored Secs,
sh network-clocks
Network Clock Configuration
Priority Clock Source Clock State Clock Type
11 Backplane GOOD PLL
Current Primary Clock Source
oops you beat me to the punch..
For what I can tell thus far the VG224 looks correct. The next thing to check is to ensure that your PRI gateway is configured correctly. Make sure that you have no slip errors on the voice gateways. If so, your missing your clocking statements.
Here is an example:
network-clock-participate slot 1
network-clock-select 1 T1 1/0/0
looks like ccm was misconfigured, missing the subscribe calling search space.
That will do it..
any thoughts on adding dids to CCM?
We originally had a pool then ran short then added more however I cant dial in to the new group but can dial out...
