Need to change Caller ID standard on FXO port
I need to change caller-ID standard from Bellcore to ETSI-DTMF on FXO port.
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
How can i do that?
1 ACCEPTED SOLUTION
Re: Need to change Caller ID standard on FXO port
You should be able to do this by changing the cptone.
Have a look here
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_c6_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1100421
BR SE DK IS NL are known to use ETSI-DTMF.
Jesse
Does anybody know the answer? or a link to some documentation?
Any answers will be highly appreciated!
Have a look here
Jesse
thanks a lot! it helps.
359
