Community Member
Need to enable the CDR reports
I would like to enable the CDR reports at my Cisco Unified Communication Manager. So i would need to know, will it impact the call process or CUCM server once if i enable the CDR report?
My Contact Center Call volume per day - 3000
CUCM ver6.0
Publisher - 1 number
Subscriber - 2 number
IP Phone model 7941
Total number of IP phones are 300
ICM - ver 7.0
CVP - ver 4.0
The abover set up having the all servers at located in a one single location.
I am expecting from your valuable reply.
D. Pandiyan.
Red
Re: Need to enable the CDR reports
The impact is trivial (we expect less than 2% impact).
One thing to note is the "Zero Duration Flag" in service parameters. Make sure you do NOT enable it unless necessary. Once that flag is enabled, it'll significantly increase the number of CDR records.
On CDR load, I'd also recommend you use "Load CDR only" option (which doesn't load the CMR). This also speeds up the CDR load.
Thanks!
Michael
http://htluo.blogspot.com
Community Member
Thanks for your reply. I think it's a bug with the ver 6.0.1 when we try to enable the CDR. And i think i need to upgrade the version. If you have any idea about this.
D. Pandiyan
Red
6.0.1 is a pretty old version. You might run into high memory/CPU usage because of the memory leak bugs.
If you experienced those symptoms, please upgrade.
Michael
190
