Need to find a directory number with Call Forward All
Hi All,
I have a user who is reporting receiving some oddly routed calls.
I noticed that the dependancy records show that there is another internal number with call forward all to this directory; but the dependancy record does not show me which directory number this is.
Can anyone help with a way to find which directory numbers are set to CFA and possibly which directory number might be set to CFA to another extension (example 12345)
Thanks very much for any help.
Amanda
1 ACCEPTED SOLUTION
The only way is via SQL
Look at this thread
https://supportforums.cisco.com/message/3330219#3330219
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Look at this thread
java
java
thanks mate.  this worked a treat
hello,
go to bulk administration
--> phones
-->generate phone reports
select all phones
select forward all, busy option from the line setting.
run the report.
you will get all the information of all the phone and you can check which phone is CFA to.
thats the only option you have.
thanks,
Vipul Jindal
Super Bronze
Or run this from the server CLI (via SSH) :
run sql select d.name, n.dnorpattern, n.fkcallingsearchspace_cfapt,n.fkcallingsearchspace_cfb,n.fkcallingsearchspace_cfbint,n.fkcallingsearchspace_cfna,n.fkcallingsearchspace_cfnaint, n.fkcallingsearchspace_cfur,n.fkcallingsearchspace_cfurint,n.fkcallingsearchspace_devicefailure from device d join devicenumplanmap dnm on dnm.fkdevice = d.pkid join numplan n on dnm.fknumplan = n.pkid
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
352
