03-27-2008 10:28 AM - edited 03-15-2019 09:41 AM
I need to see how many calls we are receiving and the only way I know how to is to run a debug command. We are using Call Manager 4.2. Is there any way to do it without watching the debug command run?
03-27-2008 10:30 AM
If running h.323 with the CM, "show dial-peer voice" would tell you this and more more informations.
03-27-2008 10:34 AM
Connect to CCM's MSSQL server by Enterprise Manager or Query Analyzer. Then choose CDR database and look into CallDetailRecord table, there should be information about all calls in your cluster.
Some more info about CDR:
http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucm/cdr_defs/4_x/cdr412.html
http://www.cisco.com/warp/public/570/avvid/voice_ip/cm_cdr/cm_cdrfaq.html
regards,
PK
