10-22-2013 04:57 AM - edited 03-16-2019 08:00 PM
Hi All
I am wondering if i can check when the phone is registered to CUCM. Like One one my user wants the report that what all are the phones(Hard Phone and SoftPhone) are resgitered to CUCM in last 6 Months.
I am wondering how we can get this report from CUCM.
I never see this report ever .
Chaman
10-22-2013 05:06 AM
Hi Chaman,
You can use Cisco Unified Operations Manager to get these kind of reports.
regds,
aman
10-22-2013 05:15 AM
Also if you want to check the time stamp of phone's last registration, then you can use RTMT (Callmanager---> device---> Device Search---> Open Device Search ---> Phone). This is just to see the timestamp, can't get the report.
08-06-2015 05:11 AM
Very useful information.
Thank you @Suresh
11-04-2017 11:47 PM
Thanks for info..
02-27-2018 12:09 AM
Hi Suresh,
Do you know anyway to download the contents information of this report?
thank you in advanced
Alfredo.
10-22-2013 07:29 AM
Can I ask what's the rationale behind this report?
If you are looking for unregistrarion, the application logs are your best friend. You cal also get some information out of the RIS with Device Queries, however this is runtime information. CUCM doesn't store this information as it's not 'valuable'
10-23-2013 01:03 AM
Hi Robert
Thanks for Reply
I want to know if i add the phones to CUCM. and after 6 month i want to know that how many phones get registered to CUCM then how can i get the information about the same.
Is there any Way or application that i can use to get the report.
Chaman
10-23-2013 09:20 AM
Assuming you have CUCM traces set to the correct level and options, you should be able to get some info from there, but there wont be anything to tell you if it was the first time they registered, or the Nth time they got registered.
10-23-2013 11:30 AM
I still fail to see the purpose. I guess if you want to see when the phone registered for the last time, you could use Device Search in RTMT as it was mentioned previously. However if the phone re-regiser you will only see the last timestamp of the registration. We don't keep historical records of registration since they have no value of CUCM. We just keep the timestamp of the last registration attempt from the phone.
Collecting traces for a 6month window is unfeasible.
09-10-2016 11:18 AM
I would like to say faced with political troubleshooting, in an environment where the network and the phones are separate departments, a report of this kind can point to a local, where phones are continuously rebooting. This kind of a report can be irrefutable when trying to prove to management their is a netw ork problem not a phone problem.
09-14-2016 09:31 AM
This is an interesting argument. Just because certain info isn't valuable to CUCM for the purpose of operations, doesn't mean it's not valuable to the consumer. Value added to the consumer should be considered when engineering solutions.
09-14-2016 10:26 AM
You can get in touch with your SE/AM to submit a PER, in there you can explain the business case of why that kind of information would be useful/necessary to have for you or your customer.
05-12-2020 02:46 AM
use the tool in the website given below to pull the registration report:
