Community Member
Need to time out an FXO port that gets left off hook
I put a -timeout call dissconnect 60- command on the port that is getting left off hook. It dosen't seem to work though. any ideas?
I call after I put the command in and the call still stays up.
1 REPLY
Community Member
Re: Need to time out an FXO port that gets left off hook
Did you try using a lower setting for "timeout call disconnect" ?
Also make sure you're using the correct signalling on the voice port.
Try this and see if it helps:
supervisory disconnect dualtone mid-call
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
Please rate useful posts.
Guilherme
150
