Community Member
Need to upgrade CCM system! Help!
My company is looking to upgrade our CCM system infrastructure.
Our setup:
We have several sites at different locations which have high-speed VPN links to each other.
Currently, our CCM system is hosted at the main HQ location.
Our Problem:
If the VPN link drops/dies, our phone system is unavailable.
Is there a way we can add infrastructure/software so that we can use a server on-site as a primary and the server at the HQ as a secondary?
We can't risk any more dropped calls since our VPN link goes into maintenance quite often.
Any advice would be greatly appreciated.
Filip Korngut
Assuming you meet the
Assuming you meet the requirements for clustering over WAN, install a SUB at that location.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Can you provide a link to
Do you mean sub-interface?
How do you suggest it is done?
If not sub-interface, can you provide a link to what a SUB is?
Thank you.
If you're an end user, get in
If you're an end user, get in touch with your support team for this, or reach a Cisco partner for assistance
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/models.html
java
46
