Neopost postage meter @ a VG202
I got a Neopost postage meter attached to a VG202 and the VG202 is connected via h323 to CUCM 8.5.
The postage meter connects without any problems, but never charges $$$, as the connection tears down at about 60s.
Call flow is like this: Neopost----VG202---h323----CUCM8.5----h323----Cisco2921 PRI E1------ISDN Provider
See here the relevant configuration of the VG202 and the Cisco2921:
VG202:
BDVG202#sh run
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
voice-card 0
interface FastEthernet0/0
ip address 192.168.243.4 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.243.4
voice-port 0/0
cptone CH
no ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer voice 150 voip
destination-pattern 00848783867
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.240.21
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 999000 pots
description Frankiermaschine
destination-pattern 299
incoming called-number 00848783867
fax rate disable
port 0/0
Cisco2921:
STHRO001#sh run
isdn switch-type primary-net5
voice-card 0
dspfarm
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
fax protocol pass-through g711alaw
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /0/ /00/
voice translation-rule 2
rule 1 /^00/ /0/ type any national
voice translation-rule 3
rule 1 /^6/ /3265566/
rule 2 /^000/ // type national international
rule 3 /^0/ // type national national
voice translation-profile Outbound
translate calling 3
voice translation-profile SRST
translate called 2
voice translation-profile add_0
translate calling 1
controller E1 0/0/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
description STH_Voice
ip address 192.168.240.2 255.255.255.0
duplex full
speed 100
h323-gateway voip bind srcaddr 192.168.240.2
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
cptone CH
mgcp profile default
dial-peer voice 1 pots
description Swisscom
translation-profile incoming add_0
translation-profile outgoing Outbound
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
forward-digits all
incoming called-number 0848783867
voice-class codec 1
voice-class h323 1
fax rate disable
Here is a debug isdn q931 of the Cisco2921:
Nov 15 15:37:50: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00B7
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x2181, '326556699'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '0848783867'
                Plan:ISDN, Type:Unknown
Nov 15 15:37:50: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80B7
Nov 15 15:37:51: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80B7
Nov 15 15:37:53: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80B7
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov 15 15:37:54: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x80B7
        Date/Time i = 0x0B0B0F0F25
                Date (dd-mm-yr)   = 11-11-15
                Time (hr:mnt:sec) = 15:37:76
        Connected Number i = 0x0183, '0848783867'
Nov 15 15:37:54: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x00B7
Nov 15 15:37:54: ISDN Se0/0/0:15 Q931: RX <- FACILITY pd = 8  callref = 0x80B7
        Facility i = 0x91A11B02024D500201213012A10D810346522EA20681010A820101820100
                Protocol Profile = Remote Operations Protocol
                0xA11B02024D500201213012A10D810346522EA20681010A820101820100
                Component = Invoke component
                        Invoke Id = 19792
                        Operation = AOCDCurrency
                                Currency = FR.
                                Currency amount = 10, Multiplier = 1/100
                                Type of charging : Subtotal
STHRO001#
STHRO001#
STHRO001#sh isdn act
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
Out   326556699  0848783867                    66       0       0   0.10     FR.
STHRO001#
Nov 15 15:39:02: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00B7
        Cause i = 0x8090 - Normal call clearing
Nov 15 15:39:03: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80B7
        Facility i = 0x91A11A02024D550201233011300FA10D810346522EA20681010A820101
                0xA11A02024D550201233011300FA10D810346522EA20681010A820101
                        Invoke Id = 19797
                        Operation = AOCECurrency
                                Currency = FR.
                                AOC-E Charging association Charge Identifier 0
Nov 15 15:39:03: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00B7
STHRO001#
Any idea what I'm missing?
Peter
  • IP Telephony
I have resolved the issue with NeoPost machine connecting to the ATA-187 which is routed to PSTN thru h.323 gateway.
Please find the information as attached.
I'm stuck pretty much where you were at the time. Did the post by alvinchong really resolve the issue?
Were you successful at last?
Cheers
/David
1005
