Network Configuration password for 7960 - master reset?
I purchased a 7960 second-hand and i do not know the network configuration password. Without this I am being told by my VOIP provider they cannot make necessary changes to the phone. Is there a master reset password to access the firmware? Thank you.
Hall of Fame Super Gold
Re: Network Configuration password for 7960 - master reset?
Keep # pressed while powering on.
Release when display shows "reset sequence". Press in succession 123456789*0#.
Confirm erase network settings with '2'.
You will need the SIP firmware files as the phone will try to access them via TFTP.
my VOIP provider tried to get to the "reset sequence" display, but the phone will not respond to this. He has other 7960's that will respond to this prompt however. Any other suggestions?
I now understand that that the phone has an SIP license and I need a SKINNY (sp?) license for the phone to work thru the VOIP provider I use. Is there a way to purchase a new license and if so what is involved in doing this?
If you can access CCO for download you already have a support contract and I believe you're entitled to use the phone with whatever image you need with a third-party call agent.
i apologize for the ignorance on this subject, but I purchased the phone 2nd hand and am a private user. Do I have permissions based on this and what is CCO? Thank you again for your help.
How do i get the correct image?
160
