Network Failover not working for CUC on IBM MCS782514 platform.
Hi Guys,
I have an issue for my client where i configured Network Failover for the CUC server where it does not work on testing it. Please Advice...
I tried testing by running extended ping to see packet drop.. I did the same test while configuring NFT for CUCM, it was successful.
For CUC, THe Primary NIC stops working when the Network failover is configured, but works when Network failover is disabled.
Below are the steps which I followed for the testing of the Failover..
I tried an extended ping while unplugging the cables from the NIC to see if both the NICs are working.
Step 1:     (Pri NIC) Cable unplugged (no packet loss)
Step 2:     Reconnected Pri NIC
Step 3:     (Sec NIC) Cable unplugged ( lost connectivity)
Step 4:     (Sec NIC) Cable Reconnected (still no connectivity)
Step 5:     Unplugged both Cables from the NIC cards.
Step 6:     Reconnected (connection established)
Step 7:     Disabled Failover config
Step 8:     Unplugged cable from Pri NIC (lost connectivity)
Also below is the #Show Network Failover
Bond 0
DHCP         : disabled           Status     : up
IP Address   : 0.0.0.0     IP Mask    : 255.255.255.000
Link Detected: no                 Mode       : Auto disabled, N/A, N/A
Queue Length : 0                  MTU        : 1500
MAC Address  : xx:xx:xx:xx:xx:xx
RX stats:
bytes   :    927078071   packets :      6206513   errors :            0
dropped :            0   overrun :            0   mcast  :      1430821
TX stats:
bytes   :   1550626596   packets :      6303342   errors :            0
dropped :            0   carrier :            0   colsns :            0
Ethernet 0
IP Address   :                    IP Mask    :
Link Detected: yes                Mode       : Auto enabled, Full, 1000MB/s
Queue Length : 1000               MTU        : 1500
RX stats:
bytes   :     57893499   packets :       716541   errors :            0
dropped :            0   overrun :            0   mcast  :       715578
TX stats:
bytes   :      6055236   packets :        18689   errors :            0
Ethernet 1
RX stats:
bytes   :    869184572   packets :      5489972   errors :            0
dropped :            0   overrun :            0   mcast  :       715243
TX stats:
bytes   :   1544571360   packets :      6284653   errors :            0
DNS
Primary      :                    Secondary  :
Options      : timeout:5 attempts:2
Domain       :
Gateway      : 0.0.0.0 on Ethernet bond0
Your help is highly appreciated..
Thank you
Bijoy Jesse
176
