Community Member
Network module interface
Hi i have a question related to the component: NM-2W so can we use VIC2-4FXO with that network module within cisco 3845?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Network module interface
No.
VIC2-4FXO, if no WIC slots are available in the 3845 chassis, must be used with an NM-x1V.
No.
Silver
Hi Seifeddine
This URL will make everything clear with regards to NM-2W and supported sub modules. It would appear that the VIC2-4FXO is incompatible with NM-2W.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/ovrnetm.htm#wp1059726
Hope that helps.
Ajaz
101
