Community Member
Network Traffic Generator
Hi all
Could anyone suggest me a good Network Traffic Generator software (Free ofcourse or cheap ones) in windows platform? I am trying to setup a network where I can test and analyse the issues with VoIP packets under heavy traffic conditions. Please suggest!! I am struggling to find one. Thanks.
Re: Network Traffic Generator
Hi ADITYA
Can you find the below?.
1- For traffic generation Windows is pretty bad, especially UDP traffic  at any decent rates.
2-I would recommend the IP SLA feature in IOS to simulate VoIP and the statistics it generates are very good.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t4/htrtpvip.html
3- You can also check the following also :
https://www.netiq.com/products/unified-communications-and-voip-management/features/vivinet-assessor.html
please rate all useful information
Community Member
Thank you kamal...I will check it
Community Member
You can also try SIPp (http://sipp.sourceforge.net/). I've just started using it and it seems a capable tool, but it's fairly complex...
Community Member
Re:Network Traffic Generator
I use iperf which can be used to generate traffic. You can specify settings like tcp or udp, packet size, time etc.
It's a simple tool that is run on a source windows machine as a client and the destination windows machine as the server and you simply send traffic between the 2.
Thanks, Carl Ratcliffe
Sent from Cisco Technical Support Android App
Community Member
Thank you Carl. I will chect it
Community Member
Hi Cal,
Is there 64-bit version of iperf? I couldnt manage to find one, only 32-bit.
2866
