07-09-2009 04:50 AM - edited 03-15-2019 06:53 PM
I am using Call Manager 4.2 and for one of my users i already have a user profile and device profile in Call manager. I need to replace his Cisco 7940 with 7960 IP phone. Do i need to create a new device profile for the 7960 and Associate his exisitng user profile with new 7960 device profile? any more instructions?
07-09-2009 06:23 AM
No, the process is just the same if you're going to create specific UDPs per user instead of using default device profiles
java
if this helps, please rate
07-09-2009 06:35 AM
Are you saying i need to create a new user profile and device profile for the 7960?
07-13-2009 03:18 AM
You should be able to leave the users profile and UDP in place and just create a new profile for that phone through the menus Device>Phone>Add New.
