New POTS line at a location - Dial Peer Question
I have a H.323 Gateway setup at one of our locations that we are adding a new POTs line to.  The problem we are having is, we have only one line going into this location.  This line is for routing local calls and for customers to call into.  When there is someone already on the line and a customer calls in they're getting a busy signal.  We'd like the new line to be the first for routing local calls to try to free up the other line.  Below is my Dial Peer rule for the outgoing calls.  Do I just add a rule above it for Port 0/0/1?
Current Setup:
dial-peer voice 2 pots
destination-pattern 7[2-9].........
port 0/0/0
forward-digits 10
After we add a line?
port 0/0/1
forward-digits 10
dial-peer voice 3 pots
port 0/0/0
forward-digits 10
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: New POTS line at a location - Dial Peer Question
Hello, Ben.
You'll want to set preferences in order to have redundant dial-peers. By default dial-peers are preference 0.
preference 2
port 0/0/1
forward-digits 10
description ***POTS - Primary Local Outbound****
preference 1
port 0/0/0
forward-digits 10
I hope this helps. Thanks!
Source
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080094852.shtml
Hello, Ben.
preference 2
port 0/0/1
forward-digits 10
preference 1
port 0/0/0
forward-digits 10
Source
Thank you for the reply Raymond!
182
