New to IP phones , trying to understand how the built In switch works
Hi.I would like to get a better understanding of how the built In switch works In an IP phone.
  As I understand It:
  One port connects to a main switch and Is a trunk port.
  There Is an Internal access port that connects the voice vlan to the phone.
  There Is another physical access port that connects the pc to the data vlan.
   Is that correct ?
1 ACCEPTED SOLUTION
Blue
Re: New to IP phones , trying to understand how the built In swi
You are correct in understanding tht access port can not have two vlans. But here in case of Cisco deployment we have special commands which will make access port prat of two vlan, one would be data/native vlan and another would be voice vlan. No other third vlan can be part of it.
The voice VLAN feature enables access ports to carry IP voice traffic from an IP phone on smae access port which carry dta vlan ports. It is how we have implemented/coded our IOS for working access port for two vlans.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
hi,
IP phone will have two ethernet port. One will connect to port on  a Switch  and another will connect to PC ( PC port ).
The one port which is connected to switch is not a trunk port, it is access port only but have two vlan assigned, one is data vlan and one is Voice vlan. PC connected PC potr on phone will get ip from the data vlan and IP phone will get ip from Voice valn.
Let me know if you need more details.
Ronak Patel
Rate helpful posts.
Hi.Thanks for the Info!
  If the port connected to the switch Is an access port then how can It have 2 Vlans assigned ? My knowledge of Vlans Is that an access port Is assigned to 1 Vlan only.My knowledge however Is not that great!
I Just read this thread which helped me understand (not completely) how there can be two vlans on an access port.I guess thats the whole point of using the voice vlan command , to allow this configuration.   https://learningnetwork.cisco.com/thread/35115
Blue
Ronak Patel
Rate helpful posts.
Thanks.I have a better understanding now.
Hi ,
        You can take a look at this link
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/sip/7_5/english/administration/guide/sipovr75.html#wpxref77776
Abdul
please rate helpful posts!!!
Thank you! thats helpful.
736
