New Unity/Failover Server Install problems with array
MCS-7835-H1-ECS1
Platform Configuration Disk will not install will the 6 drives on server.
Only way to do install is remove 4 drives..any suggestions?
1 REPLY
Re: New Unity/Failover Server Install problems with array
are you using the boot cds that came with the server... You usually have to configure the array with the HP disks first, then you start the load process
118
