new user in Unity
setup a new user in AD and synced the call manager, Call manager found the new user right after the sync, assigned phone, and extension. went over to unity and can't find the user, even after a resync of LDAP. Why cant Unity find the user, LDAP settings are the same.
do you assigned a primary
do you assigned a primary extension to the user in cucm enduser ?!
yes i do
yes i do
Hi,You need to add the user
You need to add the user as following:
Step 1 In Cisco Unity Connection Administration, click Users.
Step 2 On the Search Users page, click Add New. The New User page opens.
Step 3 In the User Type list, click User With Voice Mailbox.
Step 4 In the Based on Template list, click VoiceMailUserTemplate.
Step 5 Enter information in the following two required fields, which are marked with an asterisk (*):
Alias
Extension
Step 6 Enter information in the optional fields, as applicable. (For field information, on the Help menu, click Help for This Page.)
Note that the SMTP Address field is optional in the sense that if you do not enter a value, Connection uses the alias to form the SMTP address. However, the SMTP address cannot include non-ASCII characters. Thus, if the user alias contains non-ASCII characters, you must provide an acceptable SMTP address.
Step 7 Click Save. The user ACCOUNT has been created, and the Edit User Basics page opens.
Step 8 Enter additional information, as applicable. If you change any settings on the page, click Save.
Source:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/user_mac/guide/2xcucmac080.html
Mohamed Helmy
Regards, Mohamed Helmy
if i want to Manually create
if i want to Manually create it yes that will work. i should of said that i have been importing the users from LDAP and that has been working fine. until this one user.
38
