Community Member
new user on CCM 5.0
I have a CCM 5.0 on VMware, this is my first work on CCM 5.0, I loged on with the administrator account, then something like admin: appears, when I pressed (?) there are some linux commands like: set, file, utils,...
I simply want to log into callmanager main window locally, I've gotten stucked with no idea what to do ...
please help
Community Member
Re: new user on CCM 5.0
any ideas please??!
thanks
To configure callmanager, you need to use a web browser from your PC. The IP address of the callmanager you configured during the installation process, you need to use that ip to browse to the following address.
https:\\\ccmadmin.
Web login username should be CCMAdministrator and the password should be what ever you configured during installation.
CCM 5.0 runs on linux, so what you are seeing is the CLI of the callmanager and the commands you see are a limited set of OS administration commands.
Sankar
PS: please remember to rate posts!
Community Member
so I can't open CCM main window locally on the server where this CCM installed??!!!
On the server itself, only access is via CLI. Limited set of OS administration commands.
Sankar.
117
