Newbie: configuring T1 - help needed
Dear all,
now I have telephony line: ISDN PRA (30B+D) and PSTN gateway is AVAYA.
Now, instead AVAYA I want to connect telephony line to Cisco 2921 with voice card:
1 Channelized (E1 or T1)/PRI port
How can I start to configure cisco as pstn gateway?
Re: Newbie: configuring T1 - help needed
Hi ,
        You can follow the link below.
http://www.cisco.com/en/US/docs/ios/12_0/dial/configuration/guide/dcchant.html
here is an example with are few commands that you need to configure.
R1(config)# isdn switch-type     (this is global command to specify switch type)
R1(config)#controller t1 3/1    (Specify a T1 controller on a Cisco router with slot-3 here and port -1 here )
R1(config-controller)#framing esf   (Define the framing characteristics as Extended Superframe Format -ESF)
R1(config-controller)#linecode b8zs  (Define the line code as binary 8 zero substitution (B8ZS) )
R1(config-controller)#pri-group timeslots 1-3 service mgcp  (Configure ISDN PRI.)
R1(config-controller)#no shut
R1(config-controller)#exit
R1(config)#isdn switch-type         ( ni is fot T1 and net5 is for E1)
R1(config)#int s3/1:23     (Specify D channel on the serial interface for channelized T1)
R1(config-if)#isdn bind-l3 ccm-manager  (Bind it with call manager )
R1(config-if)#isdn outgoing display-ie
R1(config-if)#exit
Please rate helpful posts!!!
Abdul
Hall of Fame Super Gold
You answer above assumes that one has to use MGCP.
That is not a correct assumption, in  most cases using H.323 or SIP would bring better results.
Blue
1st you have to decide which protocol you want to use for the regestration/Integration.
If you decide MGCP
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
If you decide SIP or H323
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Also do not forget to use "network-clock-participate " command.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
275
