newbie: need help with SIP trunk on cme 4.1
cisco 2651XM router
cme 4.1
several 7940G ip phones
I've managed to get a small network of ip phones working on my cisco router but I need help configuring a SIP trunk so a phone (or phones) can make outside calls to PSTN landlines. I've got an account with a sip provider and they've supplied me with a list of settings. It's down to me to configure the router but i'm having difficulty. The router is connected to the internet on fastethernet0/1.
The settings the sip provider have given are:
Domain: sip.mysipprovider.com
Proxy Server Address: sip.mysipprovider.com
Proxy Server Port: 5060
Registrar Server: sip.mysipprovider.com
Registrar Server Port: 5060
Outbound Proxy: sip.mysipprovider.com
Outbound Proxy Port: 5060
SIP Signalling Port: 5060
User ID / Authentication Name: 010101010101 (my sip phone number)
Authentication Password: xxxxxxxxx (my sip password)
I tried following the cisco docs to enter the commands for sip trunking but I can't get it to work.
Firstly, I expect I'd have to press a certain button on the phone to get an outside line - I tried to configure button 9 but this doesn't work. For the moment I'm not worried about voicemail or call forwarding or any extras, I just want to get an outside connection going.
Attached is the running-config of my router.
Thanks for any help.
  • IP Telephony
Re: newbie: need help with SIP trunk on cme 4.1
A quick look showed these two problems:
Dial peer 2 should have a pattern of 9.T instead of 9.
You also do not have a name server defined to do a lookup on the sip provider's DNS.
hth,
nick
nick thankyou for your response. I altered the dial peer 2 and now when I press 9 on the phone it asks 'Enter number' which is good. But when I dial a PSTN number nothing happens.
My sip provider did not provide a name server in the settings they sent me (see first post). They only sent me 'sip.mysipprovider.com' and I can't enter that as a name server in the cli. Under sip-ua I do have:
registrar dns:sip.mysipprovider.com expires 3600
sip-server dns:sip.mysipprovider.com
but maybe this is not enough (?).
Should I ask the sip provider for their DNS details?
Thanks for any further advice.
Your ISP should be able to give you a DNS IP address.
Alternatively, you can use a public DNS server. Here's a list:
http://theos.in/windows-xp/free-fast-public-dns-server-list/
You should be able to ping sip.myprovider.com when it's done. If they don't allow pings, you should at least see the ping resolving to an IP address.
hth,
nick
I see what you mean now, yes it was easy putting in dns addresses of my isp, but this sip trunk still does not work. The internet connection worked fine on what it had before anyway. I don't know what I'm doing wrong or what I'm missing.
I can ping my sip provider from a PC and I get 4 replies so there's no problem there. If I ring my sip number from a pstn phone I get a message saying my number is 'unavailable' so I don't think my router is even registering with my sip provider. I can ping the sip provider from both a PC and the cli and success is 100%.
Are there any tests one can do to test a sip trunk? Thanks if you can help any further.
You can do some of these steps:
Try setting a translation profile out to make sure that the number that they want to see is shown as the calling number. You can also use the sip-ua command 'calling-info sip-to-pstn number '.
Make sure that the number you're trying to register is a defined number in CME or a pots dial peer. You can use 'show sip register status' or 'show sip status registrar' to see which numbers are trying to register. I don't recall which one of those is the one you're working on, since the last two words just flip :)
debug ccsip messages - this will show you what's going on between you and the provider.
From here - there are more than a dozen reasons why calls may not work and it's not something that can be easily speculated upon.
hth,
nick
ok thanks. I don't know how to set a translation profile. I did 'calling-info sip-to-pstn number ' and after that I did 'show sip register status':
cme#show sip register status
Line --- peer --- expires(sec) --- registered
01 ------ 20001 ---- 64 -------- no
02 ------ 20002 ---- 110 ------- no
03 ------ 20003 ---- 178 ------- no
cme#
I then tried 'show sip status registrar' but all I got was this:
cme#show sip status registrar
Line destination expires(sec) contact
--------call-id
--------peer
cme#
anyway above it's clearly showing me that my phones are not registered. So I need to register a 'phone', is that right? if so, what is the command to do that?
I also did:
cme#debug ccsip messages
SIP Call messages tracing is enabled
so how do I look at any results generated by the above command?
thanks for any further advice.
ephone-dn x
number
To see the debugs:
term mon
conf t
logg mon
Translation profiles:
voice translation-rule 1
rule 1 /.*/ /555/
voice translation-profile 1
translated calling 1
dial-peer voice 1 voip
description outgoing sip dial peer
session protocol sipv2
session target sip-server
translation-profile outgoing 1
hth,
nick
thanks for those commands, I put them in but still no improvement. sip register status still shows 'no' under registered: I need to get one thing sorted out: do I press 9 to get an outside line? at the moment if I press 9 I get a delay of a few seconds and then an engaged tone. If I press 9 and then dial a number I get the same thing. If I press 9 am I supposed to hear a different dial tone? I need to establish what it is I'm supposed to do on the phone to use the sip trunk.
Secondary dialtone is not there by default. This is something configured manually. Since you have 9.T as your destination pattern it will take 10 seconds to dial. If you'd like to fix this, I would do a Cisco.com search on dial peers and look at SRNDs on voice design to get a better idea of how it works.
Other than that, you will need to look at the sip messaging to see if the SIP messaging is getting out, if the provider is receiving it, if the provider is responding, if the provider is sending the response to you, if the response is correct, and if you are sending the right information in your SIP messaging.
Basically - lots of IFs - can't speculate.
287
