Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
NFAS and Dial-Peers
So I’ve got an NFAS setup in my lab and would like to just confirm something around dial-peers. According to the cisco documentation I should be creating a dial-peer referencing the port:D. However the router will not let me do that.
Documentation example:
http://www.cisco.com/en/US/docs/ios/voice/isdn/configuration/guide/vi_nfas_dch_bkup.pdf
The following example shows configuration of a POTS dial peer with the primary controller of an NFAS
group:
dial-peer voice 35 pots
incoming called-number 45...
destination-pattern 35...
direct-inward-dial
port 1/0/0:D
prefix 35
My configuration is as follows:
card type t1 0 0
card type t1 0 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/1/0
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 0
controller T1 0/1/0
pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 0
voice-port 0/0/0:23
voice-port 0/1/0:23
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
TL;DR
So the question is, can I just create a dial-peer pointed to 0/0/0:23 which is my primary D channel in the NFAS group and it will distribute the calls across all members?
Example:
dial-peer voice 100 pots
destination-pattern 9T
port 0/0/0:23
Rate helpful posts
Blog - http://tripplehelix.net
~~~ Rate helpful posts Blog - http://tripplehelix.net
Everyone's tags (4)
NFAS and Dial-Peers
Were you able to  resolve the above issue by just using the port 0/0/0:23 command ??
Appreciate you reply.
simah.
NFAS and Dial-Peers
That's correct pointing it at the primary D channel will distribute calls across all member PRIs.
Rate helpful posts
NFAS and Dial-Peers
NFAS Groups are really clunky and awful unless you run 4 or more PRIs at a given location. You really don't gain anything by building it as NFAS with only two PRIs.
Better to set it up as a trunk-group in that scenario. Less headache.
Chuck
NFAS and Dial-Peers
But , then did you also configure the second set of dial-peers (with different preference) pointing it to the backup D channel Contoller as well ?? to support an event when the first PRI link is down ??
Simah.
999
