NFAS w/DMS250
mtashiro
I am trying to configure NFAS with DMS250 but it does not look like that switchtype is supported. Is there an alternate switchtype that is compatible or do I need to have carrier change?
Rob Huffman
Hi Mark,
According to the info I have read, DMS-250 is a supported switchtype. Have a look;
ISDN NFAS Prerequisites
NFAS is only supported with a channelized T1 controller and, as a result, must be ISDN PRI capable. Once the channelized T1controllers are configured for ISDN PRI, only the NFAS primary D channel must be configured; its configuration is distributed to all the members of the associated NFAS group. Any configuration changes made to the primary D channel will be propagated to all NFAS group members. The primary D channel interface is the only interface shown after the configuration is written to memory. The router must connect to either an AT&T 4ESS, Northern Telecom DMS-100 or DMS-250, or National ISDN switch type
ISDN Switch Types and Supported NFAS Types
Lucent 4ESS
Custom NFAS
Northern Telecom DMS-250
Custom NFAS
Custom NFAS
Lucent 5ESS
Custom (Does not support NFAS)
Lucent 5ESS
NI NFAS
AGCS GTD5
NI NFAS
Other Switch Types
NI NFAS
From this doc;
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d9843.html#wp1001021
Hope this helps!
Rob
Please remember to rate helpful posts.....
I am trying to change the switchtype on the gateway. THis is all that is availabe:
MTWA-VGWY-TELCO(config)#int s0/0/0:23
MTWA-VGWY-TELCO(config-if)#isd
MTWA-VGWY-TELCO(config-if)#isdn sw
MTWA-VGWY-TELCO(config-if)#isdn switch-type ?
primary-4ess Lucent 4ESS switch type for the U.S.
primary-5ess Lucent 5ESS switch type for the U.S.
primary-dms100 Northern Telecom DMS-100 switch type for the U.S.
primary-net5 NET5 switch type for UK, Europe, Asia and Australia
primary-ni National ISDN Switch type for the U.S.
primary-ni2c The Cisco NAS-SC switchtype based on NI2C.
primary-ntt NTT switch type for Japan
primary-qsig QSIG switch type
DMS-250 is not an option. This is the same for the controller.
is there an option for DMS-250? Thanks!
Hmmmmmmmmm, that is odd. Did you try DMS100?
Rob
That is what i am going to do. Wondering if there will be any issues.
