NIC teaming Call Manager 6.1.2
How is NIC teaming enabled on UCM 6.1 servers. I thought it was via the "set network failover" command but I am not able to get this working
Re: NIC teaming Call Manager 6.1.2
It is indeed. The full command is:
set network failover enable
Is NIC teaming is supported on Call manager 6.1.2 (IBM platform)
Hall of Fame Super Red
Hi Asim,
NIC Teaming Support
Server platforms with dual Ethernet network interface cards (NICs) can support NIC teaming for network fault tolerance with Cisco Unified Communications Manager. Cisco began support of NIC teaming on HP servers in the 5.0(1) release and began support on IBM servers in the 6.1(2) release. This feature allows a server to be connected to the Ethernet via two NICs and, hence, two cables. NIC teaming prevents network downtime by transferring the workload from the failed port to the working port. NIC teaming cannot be used for load balancing or increasing the interface speed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412614
Hope this helps!
Rob
Thanks rob,
Can you give me sample configuration for enabling Teaming on cisco Call manager 6.1.2(IBM)
thanks in advance
It's the same command listed above.
572
