NIC Teaming CUCM 8.0?
shikamarunara
Level 4
Level 4
     I'm curious to know more about NIC teaming for CUCM 8 servers.  From what I understand, running the command set network failover enable will enable this feature, but am wondering how this affects the licenses I've already uploaded (as they are associated with the server's original interface.)  Is this all I need to run?  Is there a document I can refer to to read more?
I'm also interested in doing this for CCX 8.0 as well.
2 Accepted Solutions
Aaron Harrison
For CUCM there's no effect on licensing - older versions use the first physical NIC MAC, newer use a generated 'license MAC' anyway.
On previous versions of UCCX nic failover was not supported as the second NIC was assigned for SPAN, this version doesn't use the second NIC in that way so as far as I can see you can enable failover on that and it will work the same way as CUCM (i..e the license MAC won't be affected).
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Rob Huffman
Hi Shikamarunara,
Hope all is well with you You should be good to go with the Licensing question.
"NIC Teaming for Network Fault Tolerance
The NIC teaming feature allows a  server to be connected to the Ethernet via two NICs and, therefore, two  cables. NIC teaming prevents network downtime by transferring the  workload from the failed port to the working port. NIC teaming cannot be  used for load balancing or increasing the interface speed.
Hewlett-Packard  server platforms with dual Ethernet network interface cards can support  NIC teaming for Network Fault Tolerance with Cisco Unified CM 5.0(1) or  later releases.
IBM server platforms with dual Ethernet network interface  cards can support NIC teaming for Network Fault Tolerance with Cisco  Unified CM 6.1(2) and later releases. "
And the command to do that as per  the CUCM OS CLI Reference Guide is:
"set network failover
This  command enables and disables Network Fault Tolerance on the Media  Convergence Server network interface card.
Command Syntax
failover  {enable | disable}
Parameters
enable enables Network Fault Tolerance.
disable  disables Network Fault Tolerance.
Requirements
Command privilege level: 1
Allowed  during upgrade: No "
The referenced guides:
SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/callpros.html#wp1151635
CLI Ref
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp40017
Cheers!
Rob
9 Replies 9
Aaron Harrison
Aaron
Thanks for the validation, Aaron, much obliged.
Thank you Aaron, very helpful,
Hi All, Looking for a good explanation from Cisco CCBU on "why" this network failover (NIC Teaming) configuration, would not be supported? We have the ability to enable the network failover on CLI and works perfectly fine. Think I'll take this up with our local accounts team... any feedback would be much appreciated. Thanks, Yavuz
Rob Huffman
Hi Shikamarunara,
Command Syntax
Parameters
Requirements
SRND
CLI Ref
Cheers!
Rob
Hey Rob,
     How's it going, buddy.  Appreciate the input as alway.
Hi Chris,
Life is great Hopefully for you as well my firend!
Cheers!
Rob
Thanks, Mr. Huffman.  How's the weather in Calgary
Hey Shikamarunara,
You are most welcome
We went straight from Spring to Fall here in Calgary this year
Cheers!
Huff
