NIC teaming on Call Manager 7.1.5
Is there any way to NIC teaming on Call Manager 7.x. I had read somewhere it is possible. If anyone know how to or point me to a guide will be helpful.
Thanks...
Hall of Fame Super Red
Re: NIC teaming on Call Manager 7.1.5
Hi Rohan,
"NIC Teaming for Network Fault Tolerance
The NIC teaming feature allows a  server to be connected to the Ethernet via two NICs and, therefore, two  cables. NIC teaming prevents network downtime by transferring the  workload from the failed port to the working port. NIC teaming cannot be  used for load balancing or increasing the interface speed.
Hewlett-Packard  server platforms with dual Ethernet network interface cards can support  NIC teaming for Network Fault Tolerance with Cisco Unified CM 5.0(1) or  later releases.
IBM server platforms with dual Ethernet network interface  cards can support NIC teaming for Network Fault Tolerance with Cisco  Unified CM 6.1(2) and later releases. "
And the command to do that as per  the CUCM OS CLI Reference Guide is:
"set network failover
This  command enables and disables Network Fault Tolerance on the Media  Convergence Server network interface card.
Command Syntax
failover  {enable | disable}
Parameters
enable enables Network Fault Tolerance.
disable  disables Network Fault Tolerance.
Requirements
Command privilege level: 1
Allowed  during upgrade: No "
The referenced guides:
SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043624
CLI Ref
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp40017
Cheers!
Rob
Yes, you can.  It's NIC teaming but only for failover.  From the CLI, issue "set network failover enable".
Hailey
Please rate helpful posts!
Command Syntax
Parameters
Requirements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html#wp40017
EDIT: You beat my searching skills guys
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
When you do NIC teaming, do you need contact Cisco to get new license files
because the mac address is not virtual and I believe it changes?
Super Bronze
No - the licensing system is clever enough to just take the first NIC physical MAC rather than the virtual team MAC. So nothing changes.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Guys,
I have a issue with the NIC teaming..
Fault tolerance is configured in my cucm.
I'd like to set the Speed and Duplex from the CM's End..
iI've added the Show network failover
admin:show network failover
eth0 has been overridden by Network Fault Tolerance.
To view the Ethernet port configuration, please use following command:
Bond 0
DHCP         : disabled           Status     : up
IP Address   : 138.241.118.34     IP Mask    : 255.255.255.224
Link Detected: yes                Mode       : Auto disabled, full, 100MB/s
Ethernet 0
IP Address   :                    IP Mask    :
Link Detected: yes                Mode       : Auto enabled, Half, 100MB/s
Ethernet 1
DNS
Primary      :                    Secondary  :
Options      : timeout:5 attempts:2
Domain       : localdomain
Gateway      : 138.241.118.33 on Ethernet bond0
Now i need eth0 to be set to Full dupled and speed 100MB/s
would using the command #set network nic eth0 speed/duplex  solve my issue...
Any help highly appreciated...
Thank you guys
3619
