NIC teaming
Does Cisco support nic teaming on ,
a. Cisco Unified Mobility Manager
b. Cisco Unified Operations Manager
c. Cisco CER
Sankar.
Bronze
Re: NIC teaming
Sankar,
can tell about Operations Manager. Teaming is supported on UCOM.
regards
mehmet
Re: NIC teaming
Mehmet,
Thank you for your response.
Sankar.
Re: NIC teaming
NIC Teaming is function of OS, not CallManager itself. So, if you are using Cisco approved platform, NIC teaming is supported. I believe that only very old servers were supplied with one NIC, all decent servers have two NICs, and the can be teamed by using appropriate HP or IBM driver. Again, it does not matter what application you run on a server.
Good luck,
Mike
PC Headset Adapters for Cisco IP Phones
http://www.headsetadapter.com
Re: NIC teaming
Mike,
That makes sense. I have so far successfully done teaming on Unity and CM 5.0. IPCC doesnt support teaming. Will be configuring teaming on CUOM soon.
With Mobility manager i dont see any command in linux CLI like in Callmanager 5.0 (set network failover enable). So not sure if this is possible with Mobility manager.
Sankar.
193
