Nigeria FXO to RJ11 pinouts
Does anyone know what the correct RJ11-RJ11 pinouts are for connecting an FXO port to a Nigerian RJ11 PSTN socket?  Also, does anyone have a working voice-port config?  I'm in the UK and i'll have VPN access to the ISR but i want to configure as much as possible before sending it out.
voice-port 0/0/0
translation-profile incoming Inbound
translation-profile outgoing Outbound
cptone NG
timing sup-disconnect 85
impedance complex3
description *** FXO Breakout to PSTN ***
Thanks in advance,
Jason
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Either will work. FXO loop-start has no polarity.
Re: Nigeria FXO to RJ11 pinouts
FXO/FXS pinout is the same anywhere in the world: central pair on RJ11.
You may have to configure disconnect tones. Data from databases may or may not be correct.
Is that crossover or straight-through?
Jason
Thanks Paolo, much appreciated.
Thanks for the nice rating, and good luck!
703
