Night Service fail with hunt-group CME 8.6
I am configuring the night service in a CME, when this is aplied to a single ip phone, works fine, but when is aplied to a extension withing a hunt-group fails, is imcompatible this feature with the hunt-groups?
This is the hunt-group configuration
ephone-hunt 7 sequential
pilot 1007
list 4116, 4114
final 4114
preference 1
timeout 20, 60
Extension 14 and 16 are into this hunt-group.
This is the configuration in telephony-services:
night-service day Thu 11:00 11:30
night-service code *1234
And the ephone-dn 16 and 16:
ephone-dn  16 dual-line
number 4116
pickup-group 105
call-forward night-service 4111
night-service bell
ephone-dn  14  dual-line
number 4114
pickup-group 105
night-service bell
But in this extension works fine because is not into a hunt-group
ephone-dn  17  dual-line
number 4117
pickup-group 105
night-service bell
As I said, is incompatible night service with extension into a hunt-group?
Thanks and Regards!!
You have to bounce the incoming call through an ephone-dn first which has the command call-forward night-service xxx where xxx is the extension of the number you want the call diverted to and a call-forward all to the pilot number of your hunt group. You dont assign this extension to a phone.
ephone-dn XX dual-line
number 123456
name Main Number
call-forward all 655
call-forward night-service 651
hold-alert 30 originator
night-service bell
With this example an incoming call will be forwarded to the hunt group with a pilot number of 655. Or if night service is enabled the call will be forwarded to extension 651 which could be a GDM or a phone.
Hope this helps. I do agree and even I know, that this is not a perfect solution. But still for the time-being atleast something is working.
Thanks & Regards,
Venkitesh
Re: Night Service fail with hunt-group CME 8.6
we have a hunt group 1000 with following directory numbers as members
4000
4001
All calls during the day should be handled by this hunt group and all out of hours calls should be handled by another hunt group 2000 which has following members
2000
2001
As we know there is no night service option for hunt group, what we will do is that we will forward all incoming calls to directory number and we will configure that directory number to forward all calls during the day to hunt group 4000 and all out of hours call should be forwarded to hunt group 2000.
ephone-dn 3
number 1111
call-forward all 4000
call-forward night-service 2000
hold-alert 30 orignator
night-service bell
This directory number is used as landing point for incoming calls from where calls are forwarded to different hunt group depending upon time of the day.
ephone-dn 4
number 4001
no huntstop
ephone-dn 5
number 4002
no huntstop
ephone-dn 5
number 2001
no huntstop
ephone-dn 6
number 2001
no huntstop
ephone-hunt 1 longest-idle
pilot 4000
list 4001, 4002
final 4003
timeout 15,15
ephone-hunt 2 longest-idle
pilot 2000
list 2001, 2002
final 2003
timeout 15,15
The final destination in hunt group 1 is configured as 4003 but it can be another hunt group as well if required.
Thanks & Regards,
Venkitesh
Message was edited by: Venkitesh H Iyer
Ok, i tried to forwall instead of a extension of a hunt-group, as you said, to a pilot, let´s if this run, I hope.
But what I dont understand is the forward all within a extension to a pilot, because in this way I think that you could not call directly a extension, always will be forwarded to the pilot.
The problem in this scenario is that I have several hunt-group with different list of extension, so I can not forward to a pilot, but the night-service should run.
About pickup-group, do you know how can an extension capture directly a call to another extension, for instance one secretary want to take an incoming call to his boss.
I saw it with fac custom service-direct but when i enable this in telephony-services, the pickup local stop running.
Any idea? Thanks !!!!
1023
