ā01-15-2014 03:01 AM - edited ā03-16-2019 09:15 PM
I've configured the following on a CME.
night-service day Sun 07:30 07:29
night-service day Mon 16:30 07:29
night-service day Tue 16:30 07:29
night-service day Wed 16:30 07:29
night-service day Thu 16:30 07:29
night-service day Fri 16:30 07:29
night-service day Sat 07:30 07:29
ephone-dn 20
number 1234
name Night Test
call-forward night-service 8888
8888 is the VM number. All other extensions on this CME work fine and forward to VM upon NOAN / Busy etc.. depending on how I have configured them.
When I dial the above xtension 1234 (during the configured night hours) it just rings constantly and does not divert to 1234. Am I missing something?
Solved! Go to Solution.
ā01-15-2014 07:10 AM
Few guess if that works.
Enable night service code-
telephony-service
night-service code *99
Go to ephone and add "night-service bell"
Now press *99 from your phone to activate night service and check.
Is date/time on phone correct ?
Manish
ā01-15-2014 03:05 AM
Time of Day Routing
There is no start forward method to achieve ToD routing in CME similar to CUCM. However, there are different workarounds to achieve it. I liked doing it as per Cisco Support Forum Docs using Night-Service and summarized step-by-step below.
1. Define Night-Service time slots
telephony-service
night-service day Sun 08:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 17:00 07:59
night-service day Sat 08:00 07:59
2. Configure call-forward night-service command under the ephone-dn.
ephone-dn 19
number 8500
label Front Desk
name Front Desk
call-forward busy 9201
call-foward noan 9202 timeout 10
call-forward night-service 8501
night-service bell
- Assuming 8500 is the Front Desk number. As per the above configuration of ephone-dn during non night-service hours the call was forward to the 9201 and 9202 when busy or no answer.
- During night-service hours the call would be redirected to 8501 which could your Auto-Attendant number or it could be another destination. It could be pointing to a dial-peer which further points to your cell/home number. For example :-
dial-peer voice 20 pots
description == Security Room ==
destination-pattern 8501
port 1/1
- With the above configuration, the call will be sent to this dial-peer which is an Analog Phone in the security room.
ā01-15-2014 03:41 AM
This is the document i followed. I've added night-service bell but still when I dial 1234 within the night hours, it just rings instead of going straight to 8888, which I assume it should do from my config?
ā01-15-2014 03:21 AM
Add this.
night-service bell
Manish
ā01-15-2014 04:18 AM
Do u have an AA or mailbox configured for this ext number?
Can u give us a debug voice dialpeer inout please when dialing this number
ā01-15-2014 06:11 AM
Hi There,
Yes there is a mailbox configured for this extension 1234. I amended the ephone-dn to test, with the following and it diverted to VM after timeout 5.
ephone-dn 20
number 1234
name Night Test
call-forward noan 8888 timeout 5
As soon as I amend the DN again with below, it doesn't divert (even though its now within the night hours). It just rings and rings.
ephone-dn 20
number 1234
name Night Test
ā01-15-2014 06:28 AM
Can you Router and Phone date/time , is it synced ? Showing correct time?
Manish
ā01-15-2014 06:34 AM
curent time on the router is correct for the timezone - and falls within my night service hours (I think) from my understanding anyways.
20:33:57.630 TJM Wed Jan 15 2014
ā01-15-2014 06:45 AM
Have you tried it like this as per Manish suggestion?
ephone-dn 20
number 1234
name Night Test
night-service bell
ā01-15-2014 06:56 AM
This is how it stands at the moment.
ephone-dn 20
number 1234
name Night Test
night-service bell
I can't understand why it won't divert.
telephony-service
Manish
ā01-15-2014 08:04 AM
That looks to have worked! I didn't read anywhere about that command to actually switch it on.
night-service code *45
Seems to have done the trick.
Thank You!
ā01-15-2014 07:13 AM
