Night Service
I have a customer using cm version 7.1 with unity
The customer wants a flexible night service where by calls to extensions or hunt pilots are automatically forwarded to voicemail.
Currently I have set up Time of day routing for this.
The customer also wants the ability to manually override the pre set times so if they want to close early or open later they have an option on the phone or web page etc.
This is the bit I am struggling with as apart from letting the user change the time periods I can’t see how to let a user override the time of day settings any ideas?
Re: Night Service
It's easier if you just create a new call handler with the same greeting and have user CFA to a CTI RP.
Then just tell them to CFA their phone.
If you want to keep the TOD idea that means you'll probably need to create time periods of 1 hour and instruct a user on how to change it via CCMAdmin.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: Night Service
CFA wont work for huntgroups though.
so if we have
HP= 100
DN:1= 200
DN:2=300
DN:3=400
after 6pm HP 100 diverts to VM message "sorry we are closed"
There must be a way to manually override the time period from and divert 100 back to the line group.
could I do some thing like assign the DDI to a dummy phone. in normal oporation divert the line to the HP 100 in PT A. to manually override it the user would have to divert the line on the DDI to another HP i.e *100 which is in a PT not controlled by a time period .
208
