10-09-2009 02:37 AM - edited 03-15-2019 07:59 PM
Dear all,
Is it possible to configure NM-4B-S/T ISDN BRI Module on an ISR router for my connection to the PSTN for voice? Or do i need to use the VIC one?
Solved! Go to Solution.
10-09-2009 04:29 AM
Hi Jean,
Sadly the NM-4B-S/T does "not" support voice.
Voice Hardware Compatibility Matrix (Cisco 17/26/28/36/37/38xx, VG200, Catalyst 4500/4000, Catalyst 6xxx)
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
Hope this helps!
Rob
10-09-2009 04:29 AM
Hi Jean,
Hope this helps!
Rob
10-12-2009 10:04 PM
OK.
Thanks a lot.
