NM-CUE CLI Login credential
I have NM-CUE installed on 2921 router. CUE version says 8.6. I would like to login & configure the CUE module for the 1st time. If i do a session to the module it asks about username & password. I tried cisco, cisco but it's not working. Can someone sugegst me what is the default credential??
My CME username: admin, Password: cisco
Under Telephony-service i have CME GUI username: webadmin, password: cisco
I tried using these credentials as well, still not working. I configured other parameters like IP address etc..
1 REPLY
There is no default username/password it is set at the end of the installation process, at least that is what the documentation says...
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_password_recovery09186a008042aa29.shtml#topic1
If a username/password has been set, you may got a refurbished module or a used one.
Did you try to set a admin username/password one using the cli?
Check the slot, where the CUE has been installed to and issue the following commands:
CME-router#service-module service-engine 0/0 session
Trying 10.0.0.1, 2194 ... Open
CUE#
go to config mode and configure a username password, as shown here:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_password_recovery09186a008042aa29.shtml#c5
If all fails, you may reset the module as shown in the same link.
regarads,
Kai
585
