NM-CUE Crash Recovery
galileikis
When I try to bring up my NM-CUE, I get the following mesages. Does anyone recognize this? Does anyone know how to recover from it? It promps me to enter boot information but it never seems to be able to access my FTP server.
Thanks!!
c - change boot params
e - print fatal exception
n netif - print network interface device address
$dev(0,procnum)host:/file h=# e=# b=# g=# u=usr [pw=passwd] f=#
tn=targetname s=script o=other
boot device: flash file name: /ata0/
Boot flags:
0x02 - load local system symbols
0x04 - don't autoboot
0x08 - quick autoboot (no countdown)
0x20 - disable login security
0x40 - use bootp to get boot parameters
0x80 - use tftp to get boot image
0x100 - use proxy arp
available boot devices: fei flash
[CE500 Series]: c
'.' = clear field; '-' = go to previous field; ^D = quit
boot device (flash,net) [ net]:
file name [/tftpboot/volant/ceupgrade]:
cache IP address [ 10.1.1.61]:
IP network mask [ 255.255.255.0]:
server IP address [ 10.1.1.1]:
gateway IP address [ 10.1.1.1]:
protocol (rcp,ftp,tftp) [ ftp]:
username [ autoprog]:
password [ prog]:
flags [ 0]: 0x02
ERROR Flash Block Lock Clear unsuccessful
ERROR Flash Erase unsuccessful. Sector #5
Initializing memory. Please wait. 256 MB SDRAM detected
BIOS Version: SM 02.00
BIOS Build date: 09/17/02
sadbulali
Level 4
Level 4
Looks like a BUG - CSCec51786,
press '***' when prompted and then type 'boot disk'?
1. Shutdown the CUE(
2. Powerdown the router.
3. Take out the NM.
4. Put it back in.
5. Power on the router.
